| View previous topic :: View next topic |
| Author |
Message |
Brian
Joined: 22 May 2000 Posts: 7 Location: Las Vegas, NV, USA
Posted: Mon May 22, 2000 11:04 am Post subject: CP1K/2 |
My company has a CP1K/2 UPS used to back up a computer attached to a printing press. The UPS no longer seems to function at all. I have checked the input voltages, and there is no problem there. I tried resetting the breaker, but that did nothing. I even double checked that the On/Off switch was in the ON position. No indicator lights are showing. [img]http://www.minutemanups.com/ubb/frown.gif[/img]
I could use any suggestions, or possibly information on obtaining a replacement or repairing the current one.
Brian Lusk
Network Administrator
H&H Enterprises |
| Back to top |
jmoore
Joined: 30 Mar 2000 Posts: 848 Location: Carrollton, TX 75007
Posted: Mon May 22, 2000 11:49 am Post subject: |
Brain,
The CP1k\2 may have taken a electrical surge.
Step 1 Brain have you had a chance to take the cover off of the ups?
What you are looking for inside is any indication of burnt components on your PCB board.
If you do not see any indication of burnt components.
Step 2 Brain the very next thing to consider is the age of your batteries. Has your company replaced the batteries?
Step 3 Brain what is the serial# located on the back of your UPS?
This serial# will indicate the age of your UPS. It is very important that you transpose the exact serial# off the back.
Please get back to me with that information. |
| Back to top |
Brian
Posted: Mon May 22, 2000 1:10 pm Post subject: |
Jmoore:
I just now cracked the case. No burnt components are apparent.
The batteries are likely to be the originals. Each individual battery only shows a voltage of .6v, which is either a state of extreme discharge or just plain bad batteries. The whole array of batteries shows only 3v. I will replace these batteries and see if that clears the problem.
The serial number is: 3A708607G0011 SW
The part number is: 9102-5110-00
Brian Lusk
H&H Enterprises
quote: Originally posted by jmoore:
Brain,
| Back to top |
Brian
Posted: Tue May 23, 2000 10:19 am Post subject: |
The batteries solved the problem. When we weren't getting any response, I just assumed it had to have been something more. Thanks for the assist.
Brian Lusk
H&H Enterprises
quote: Originally posted by Brian:
Jmoore:
Brian Lusk
H&H Enterprises
| Back to top |
jmoore
Posted: Tue May 23, 2000 11:56 am Post subject: |
Brian,
Your welcome
[This message has been edited by jmoore (edited May 23, 2000).] |
| Back to top |
Brian
Posted: Wed May 24, 2000 11:59 am Post subject: |
jmoore:
This morning, the CP1K/2 started beeping. It no longer appears to be providing backup power to the system. The indicator lights are working, but do not seem to indicate any fault. What's wrong now?
Brian
Brian,
Your welcome
| Back to top |
jmoore
Posted: Wed May 24, 2000 12:35 pm Post subject: |
Brain,
Whenever the power dips below 184 volts then unit goes into battery mode; you will then hear the unit beep every ten seconds and you should see a light on inverter. When the line voltage returns to normal, then the Line AC light located to the left of the inverter light should appear green. At this point you should be okay. Do you have a output on battery mode?
[This message has been edited by jmoore (edited May 24, 2000).] |
| Back to top |
Brian
Posted: Wed May 24, 2000 3:40 pm Post subject: |
When you completely unplug the UPS, it shuts down entirely after a few moments. I am fairly confident that it was working yesterday for a little while. Could the problem be heat related? The room is maintained around 75-80 degrees F.
The line and inverter lights stay green when plugged in. When you unplug from line power, it shuts down after a moment or two.
Brian Lusk
Brain,
[This message has been edited by Brian (edited May 24, 2000).] |
| Back to top |
jmoore
Posted: Wed May 24, 2000 4:18 pm Post subject: |
Brian,
1. What type of batteries did you purchase?
2. Please disconnect the positive lead and then place your voltage meter across the negative lead and the positive lead you disconnected. I need to know what the voltage across this point is. You should see 68.5 volts, then read the voltage across the each battery.
3. At that Heat factor you will be in a safe operating condition.
jeff
| Back to top |
Brian
Posted: Fri May 26, 2000 5:06 pm Post subject: |
I purchased 12v 7Ah batteries from the local heavy battery store.
Each battery measures 15.3v. The whole array of batteries measured 77.5v. The UPS shut down as soon as I disconnected the positive lead. Measuring across that lead to the negative lead resulted in 0v.
New symptom: Now, during power up, as soon as it tries to switch from bypass to the inverter, it dies with a fault light. Lights 1 and 3 on the Load Indicator are lit.
Thank for your help!
Brian
Brian,
jeff
| Back to top |
jmoore
Posted: Sun May 28, 2000 7:46 am Post subject: |
Brian,
What is the name brand is what I meant.
From this symptom it sounds like the charger has gone out. You should be measuring about 68v when you disconnect the positive lead.
The board has problems; you need either to send it in for repair or trade it in for new unit. Look at our trade-in program at the address below. [url=http://www.minutemanups.com/products/trade.htm]http://www.minutemanups.com/products/trade.htm[/url]
Jeff
[This message has been edited by jmoore (edited May 28, 2000).]
[This message has been edited by jmoore (edited May 28, 2000).] |
| Back to top |
Brian
Posted: Mon May 29, 2000 10:06 am Post subject: |
OK, that's what I figured. Who do I contact for repairs?
The batteries were "Power Source" brand. That is what the local battery shop labels them.
Thanks once again!
Brian
Brian,
Jeff
| Back to top |
jmoore
Posted: Tue May 30, 2000 7:33 am Post subject: |
Brian,
Just contact us here at Tech Support, the number is 1-800-238-7272 dial 206 for my extension
Jeff |
| Back to top |
