| View previous topic :: View next topic |
| Author |
Message |
joshv
Posted: Wed May 06, 2009 8:58 am Post subject: E 750 Beeps Three Times Every 5 Minutes |
| After a 2 hour power outage yesterday our E750 is beeping 3 times every 5 minutes. The unit worked fine during the outage and eventually ran out of battery. It is working fine now and has one green led light on the front. Everything seems normal except for this beeping. Do I need to do a self test? Any ideas? |
| Back to top |
Steve
Posted: Wed May 06, 2009 9:12 am Post subject: 3 beeps |
| You need to replace batteries. |
| Back to top |
joshv
Posted: Wed May 06, 2009 9:15 am Post subject: Indicator Light? |
| Wouldn't there be an indicator light for that? |
| Back to top |
tbuchanon
Joined: 30 Mar 2000 Posts: 156 Location: Carrollton, TX 75007
Posted: Wed May 06, 2009 2:53 pm Post subject: |
Joshv,
Please try cycling the E750 to battery mode and back. The unit might think it has a bad battery and this should clear the beeps.
Tim |
| Back to top |
joshv
Posted: Wed May 06, 2009 3:19 pm Post subject: Self Test |
| The self test (hold power button down 4 seconds until it beeps twice) fixed the issue. I probably need new batteries because of the age but the unit itself is not indicating that it needs new batteries. So it fixed the issue of it beeping every 5 minutes. |
| Back to top |
tbuchanon
Posted: Thu May 07, 2009 7:46 am Post subject: |
Joshv,
If the unit is over 4 years old, you should replace the batteries.
Tim |
| Back to top |
