New Admin of RPM 1601
Post new topic   Reply to topic    MinutemanUPS.com Forum Index -> Remote Power Manager
View previous topic :: View next topic
Author Message
mobrien8
PostPosted: Thu May 15, 2008 10:11 am    Post subject: New Admin of RPM 1601 Reply with quote
I recently took over a site that is using the RPM 1601 SN ED 15060800124.
I have never used one of these units. I was able to find the ip address of the unit and just happened to try the old "admin/admin" user/pass, and it let me in to the web interface.
I just dont know what to do from there. Is there a way to configure it from the web interface? I would like to see how it is setup to answer a call from phone line to reboot, as well as figuring out how to (or if it can) have an external ip address that i could remote into.
Again i have been aclimated to this product for roughly 2 hours now and have downloaded the userguide but would like some notes on how to better administer it.
Mike
Back to top
View user's profile Send private message
jeff
PostPosted: Thu May 15, 2008 11:41 am    Post subject: RPM1601 Reply with quote
mobrien8,
Call me...
800-238-7272 ext 206.
Jeff Moore
Back to top
jeff
PostPosted: Mon May 19, 2008 9:16 am    Post subject: mobrien8 Reply with quote
I have not received a phone call from you.
Go to this web site and follow along.
http://rpm.minutemanups.com/
user\admin
pass\admin
You will see four catergories, Information, Configuraiton, Log
Information, Device Selection
Under that heading look for the RPM Setting Tab.
Click on this tab.
You now need to make a selection RPM01.
Now you are on RPM01 and have the access to change A-H to control what you want the outlet to do.
So on your side you will follow these directions below.
You will need to type the IP address in the URL line for the RPM1601.
Under the Configuration heading look for the RPM Setting Tab.
Click on this tab.
Now you are on RPM01 and have the access to change A-H to control what you want the outlet to do when you call from a land line. This also allows you to have web access.
Let me now if you have any question:
Jeff
Back to top
Display posts from previous:
Post new topic   Reply to topic    MinutemanUPS.com Forum Index -> Remote Power Manager All times are GMT - 6 Hours
