| View previous topic :: View next topic |
| Author |
Message |
btesler
Posted: Tue May 18, 2010 6:11 pm Post subject: RPM 1601 IP Setup |
| I have a new RPM1601 with the Internet Power Management card. The documentation say the IP is 192.168.0.254. I configured my Lan card to match the documentation and connected directly to the unit from my computer and tried to connect using IE8. No Luck. Has the default IP address changed? I did reset the Lan card. I have an Amber (on top), a Green (on the Bottom) and a single green light under the Cat5 cable. |
| Back to top |
tbuchanon
Joined: 30 Mar 2000 Posts: 147 Location: Carrollton, TX 75007
Posted: Wed May 19, 2010 7:33 am Post subject: |
btesler,
192.168.0.254 is the default Gateway address.
192.168.0.215 is the default IP address
You will need to go to the Setup-Procedure on page 8 of the SNMP-32L manual and setup the SNMP for your IP address and Gateway.
Load the SNMP Utility CD into the CD-ROM drive, and then open the ‘Install SNMP Utility’.
2. Once the installation is complete, there will be a ‘SNMP Utility’ group in the Windows ’Start’ ‘Program Group’.
3. Click the “SNMP Utility” to initiate the SNMP Utility program
and configure the SNMP.
Tim |
| Back to top |
