SmartSine S1000 Question
Post new topic   Reply to topic    MinutemanUPS.com Forum Index -> Other Minuteman UPS Models
View previous topic :: View next topic
Author Message
George W. Bush
PostPosted: Wed Aug 04, 2004 2:21 am    Post subject: SmartSine S1000 Question Reply with quote
Does the S1000 provide AUTOMATIC voltage regulation? Or must I flip a switch or something when I see the voltage drop? The back picture has a "Dip Switch"..what is that for? Also, I'm going to be using this for a plasma television. Do you envision any problems with this? One more question..I'm thinking of ordering through Page Computers.com. Are they authorized? What's your policy on different internet sellers? Thanks for your time,
Chris
Back to top
View user's profile Send private message
George W. Bush
PostPosted: Wed Aug 04, 2004 4:51 am    Post subject: Reply with quote
Actually, now I'm leaning towards Provantage.com. Are they cool? Also, Provantage state that there is no return on this unit. What if I get it and there is something wrong?
Thanks again!
Back to top
tbuchanon
PostPosted: Wed Aug 04, 2004 10:02 am    Post subject: Reply with quote
George,
The Smartsine series has automatic voltage regulation. The dipswitches on the back are for changing the output voltage. When you purchase the Smartsine unit, you will receive a 3 year warranty. If at anytime during the 3 years you have a failure, you can contact Minutemanups tech support for assistance.
Tim Buchanan
Back to top
View user's profile Send private message Visit poster's website
jmoore
PostPosted: Wed Aug 04, 2004 10:09 am    Post subject: Reply with quote
Mr. Bush,
Good Morning,
Here is the specification for the S1000 series.
Powerful Features
True Sinewave Output
Line-Interactive Topology
700, 1000, 1400 and 2000 VA Units
8 Receptacles on Each Unit
Independent Battery Bypass
Fax/Modem/Data Protection
A line-interactive UPS runs constantly on incoming utility power, and uses built-in voltage regulation circuitry to adjust incoming power if it is too low or too high. The process allows the UPS to protect connected equipment from small changes in voltage without using its internal batteries. This voltage regulation extends the life of the UPS batteries and preserves backup power for when it is most needed during complete blackout conditions. MINUTEMAN’s MBK-E Series and PRO-E Series are line-interactive products that produce a simulated sinewave output on battery. By contrast, the SmartSine Series, Enterprise Series, and XRT Series are line-interactive products that produce a true sinewave output on battery.
Who ever you decide to purchase through. Minuteman Guarantees your product for three years parts and labor.
Para Systems Inc. (Para Systems) warrants this equipment, when properly applied and operated within specified conditions, against faulty materials or workmanship for a period of three years from the date of purchase.
For equipment sites within the United States and Canada, this warranty covers
repair or replacement of defective equipment at the discretion of Para Systems.
Repair will be from the nearest authorized service center. Replacement parts and warranty labor will be borne by Para Systems. For equipment located outside of the United States and Canada, Para Systems only covers faulty parts. Para Systems products repaired or replaced pursuant to this warranty shall be warranted for the unexpired portion of the warranty applying to the original product. This warranty applies only to the original purchaser who must have properly registered the product within 10 days of purchase.
800-238-7272 ext. 206 or 224 will assist you in anyway we can.
Jeff
[This message has been edited by jmoore (edited August 04, 2004).]
Back to top
View user's profile Send private message Send e-mail
George W. Bush
PostPosted: Wed Aug 04, 2004 3:47 pm    Post subject: Reply with quote
Thanks guys. I'm going to order one today. I'll be back to register the warranty and post about how it went hooking it up.
Thanks again. [img]http://www.minutemanups.com/ubb/smile.gif[/img]
Back to top
plaistedzvu
Guest
PostPosted: Fri Jul 22, 2011 3:12 am    Post subject: Hello Reply with quote
Hello all,I'm here to learned how to obtain much more value information.
Back to top
Display posts from previous:
Post new topic   Reply to topic    MinutemanUPS.com Forum Index -> Other Minuteman UPS Models All times are GMT - 6 Hours
